[GRASS-dev] is this compiler-safe?
Paul Kelly paul-grass at stjohnspoint.co.uk
Wed Feb 10 05:32:36 EST 2010
On Wed, 10 Feb 2010, Markus Metz wrote:
> I found two code snippets in the segment library (all branches) that look
> fishy to me:
> the first is in relbr6 here
> https://trac.osgeo.org/grass/browser/grass/branches/releasebranch_6_4/lib/segment/format.c#L135
> should
>   if (lseek(fd, 0L, SEEK_SET) == (off_t) - 1) {
> not be
>   if (lseek(fd, 0L, SEEK_SET) == (off_t) -1) {
> because I can't see where 1 is subtracted from? Introduced with automated
> indentation in r32527
Hello Markus,
Well, looks like a bug in the indent program that got confused by the cast
and thought the - was being used as a binary rather than unary operator.
But is it not only an aesthetic problem? As far as I can see the code
should do exactly the same thing?
> the second is in relbr6 here:
> https://trac.osgeo.org/grass/browser/grass/branches/releasebranch_6_4/lib/segment/format.c#L178
>   if ((bytes_wrote = write(fd, &x, sizeof(int)) == sizeof(int)) < 0)
> I am missing parentheses somewhere and would rather use
>   if ((bytes_wrote = write(fd, &x, sizeof(int))) != sizeof(int))
>   G_warning("%s", strerror(errno));
>   return (bytes_wrote == sizeof(int));
> just to be on the safe side
Yes I suppose you saw too that the code that calls this function assumes
if the return value is non-zero that it succeeded, which doesn't seem
right. I would suggest to make it even clearer by removing the redundant
variable x, correcting the grammar (written instead of wrote) and
rearranging:
Index: format.c
--- format.c    (revision 40905)
+++ format.c    (working copy)
@@ -170,15 +170,12 @@
  static int write_int(int fd, int n)
-    int x;
-    int bytes_wrote;
+    int bytes_written = write(fd, &n, sizeof(int));
-    x = n;
-    if ((bytes_wrote = write(fd, &x, sizeof(int)) == sizeof(int)) < 0)
+    if (bytes_written != sizeof(int))
-    return bytes_wrote;
+    return (bytes_written == sizeof(int));
I think that is yet easier to read - do you agree?
Paul
