[GRASS-dev] is this compiler-safe?
Markus Metz markus.metz.giswork at googlemail.com
Wed Feb 10 05:52:06 EST 2010
Paul Kelly wrote:
> Markus Metz wrote:
>> should
>>   if (lseek(fd, 0L, SEEK_SET) == (off_t) - 1) {
>> not be
>>   if (lseek(fd, 0L, SEEK_SET) == (off_t) -1) {
> Hello Markus,
> Well, looks like a bug in the indent program that got confused by the
> cast and thought the - was being used as a binary rather than unary
> operator. But is it not only an aesthetic problem? As far as I can see
> the code should do exactly the same thing?
I am not sure if the code would do exactly the same thing with other
compilers than gcc, but that's beyond me.
>>   if ((bytes_wrote = write(fd, &x, sizeof(int)) == sizeof(int)) < 0)
>> I am missing parentheses somewhere and would rather use
>>   if ((bytes_wrote = write(fd, &x, sizeof(int))) != sizeof(int))
>>   G_warning("%s", strerror(errno));
>>   return (bytes_wrote == sizeof(int));
>> just to be on the safe side
> Yes I suppose you saw too that the code that calls this function
> assumes if the return value is non-zero that it succeeded, which
> doesn't seem right. I would suggest to make it even clearer by
> removing the redundant variable x, correcting the grammar (written
> instead of wrote) and rearranging:
> Index: format.c
> --- format.c    (revision 40905)
> +++ format.c    (working copy)
> @@ -170,15 +170,12 @@
>  static int write_int(int fd, int n)
> -    int x;
> -    int bytes_wrote;
> +    int bytes_written = write(fd, &n, sizeof(int));
> -    x = n;
> -    if ((bytes_wrote = write(fd, &x, sizeof(int)) == sizeof(int)) < 0)
> +    if (bytes_written != sizeof(int))
> -    return bytes_wrote;
> +    return (bytes_written == sizeof(int));
> I think that is yet easier to read - do you agree?
Yes, that looks much better! AFAICT, ready to commit.
Markus M
