[GRASS-dev] is this compiler-safe?
    Glynn Clements
    glynn at gclements.plus.com
    Wed Feb 10 06:00:21 EST 2010
Markus Metz wrote:
> I found two code snippets in the segment library (all branches) that
> look fishy to me:
> the first is in relbr6 here
> https://trac.osgeo.org/grass/browser/grass/branches/releasebranch_6_4/lib/segment/format.c#L135
> should
>     if (lseek(fd, 0L, SEEK_SET) == (off_t) - 1) {
> not be
>     if (lseek(fd, 0L, SEEK_SET) == (off_t) -1) {
The two are equivalent; the whitespace isn't significant here.
> because I can't see where 1 is subtracted from? Introduced with
> automated indentation in r32527
There is no subtraction; the "-" is treated as a unary minus
(negation) operator in this context. If you were to change it to
something which cannot be interpreted as a unary operator
(e.g. / or %), you would get an error.
> the second is in relbr6 here:
> https://trac.osgeo.org/grass/browser/grass/branches/releasebranch_6_4/lib/segment/format.c#L178
>     if ((bytes_wrote = write(fd, &x, sizeof(int)) == sizeof(int)) < 0)
Ouch. There's no way that that can make sense. As it stands, it's
parsed as:
      if ((bytes_wrote = (write(fd, &x, sizeof(int)) == sizeof(int))) < 0)
i.e. bytes_wrote will be either 0 or 1, so the "... < 0" will always
be false.
> I am missing parentheses somewhere and would rather use
>     if ((bytes_wrote = write(fd, &x, sizeof(int))) != sizeof(int))
>     G_warning("%s", strerror(errno));
>     return (bytes_wrote == sizeof(int));
I would use:
	static int write_int(int fd, int n)
	    if (write(fd, &n, sizeof(int)) != sizeof(int)) {
		return 0;
	    return 1;
There's no need to make a copy of "n"; it's already a copy of the
actual argument.
Actually, looking at the code in context, I'd write:
	static void write_int(int fd, int n)
		G_fatal_error("%s", strerror(errno));
Lets face it: you aren't going to be recovering from this situation,
are you? If _segment_format fails, the module fails.
While you're there, can you fix this nonsense:
	if (file_size > INT_MAX) {
OTOH, the segment library is long overdue for being replaced with
something more efficient.
