[GRASS-dev] Some proposition on r.neighbour (new code)
Jarosław Jasiewicz jarekj at amu.edu.pl
Wed Feb 10 06:14:09 EST 2010
Glynn Clements pisze:
> Jarosław Jasiewicz wrote:
>>>> I have two propositions on r.neighbour:
>>>> 1) add existing method "range" to existing methods of r.neighbors
>>>> 2) add new method "percentile" and add it to existing method of r.neighbours
>>> Both seem reasonable, although I'm not keen on the name of the second.
>>> 1. It's likely to be confused as being similar to quart1, quart3,
>>> perc90 and quantile (quantile would have been named percentile if it
>>> used values in the range 0-100 rather than 0-1).
>> maybe name "quantile" will be better,
> method=quantile already exists; it calculates the value at an
> arbitrary quantile specified by the quantile=... option. The following
> pairs of commands are equivalent:
> r.neighbors method=quantile quantile=0.25 / r.neighbors method=quart1
> r.neighbors method=quantile quantile=0.50 / r.neighbors method=median
> r.neighbors method=quantile quantile=0.75 / r.neighbors method=quart3
> r.neighbors method=quantile quantile=0.90 / r.neighbors method=perc90
> In general, where a module offers a quantile (percentile, quartile,
> etc) option, the quantile is chosen by the user and the value at that
> quantile is returned, so using the terms percentile or quantile alone
> in this case may lead to confusion.
> OTOH, I don't have any suggestions as to a better name.
maybe relative position? or relative and description "relative position
to neigbor cells"
J.
