[GRASS-dev] Python Scripts- mapcalc
António Rocha
antonio.rocha at deimos.com.pt
Fri Feb 12 06:30:17 EST 2010
Hey
Regarding a previous message, from Glynn, about how to use mapcalc in a
Python Script in GRASS6.4. I have the following script (module hearer is
also there):
import os
import sys
import grass.script as grass
def main():
output = options['output']
raster1 = options['raster1']
raster2 = options['raster2']
grass.mapcalc("${out} = ${rast1} + ${rast2}", out = output, rast1 =
raster1, rast2 = raster2)
return 0
if __name__ == "__main__":
options, flags = grass
When I enter:
python.teste raster1=aspect at PERMANENT raster2=aspect at PERMANENT
output=Zteste8
GRASS freezes, I mean. It's still processing without stopping or exiting
or even any error. Any idea of what might be wrong?
Thanks
Best Regards
Antonio
> António Rocha wrote:
>> By the way, I'm having some difficulties in using mapcalc in a python
>> scripts.
>> I'm doing this
>> grass.mapcalc(options['output']=options['raster1']+options['raster2'])
> This isn't valid Python syntax.
> grass.mapcalc() accepts a template string followed by keyword
> arguments for the substitutions, e.g.:
> out = options['output'],
> rast1 = options['raster1'],
> rast2 = options['raster2'])
> Although, I normally copy all of the options[] into separate variables
> at the beginning of main(), i.e.:
> def main():
> out = output,
> rast1 = raster1,
> rast2 = raster2)
__________ Information from ESET NOD32 Antivirus, version of virus signature database 4860 (20100212) __________
The message was checked by ESET NOD32 Antivirus.
http://www.eset.com
