[GRASS-dev] [GRASS GIS] #934: d.vect with z height colors uses a
random polygon point for height - patch to fix attached
trac at osgeo.org
Sun Feb 14 16:03:22 EST 2010
#934: d.vect with z height colors uses a random polygon point for height - patch
to fix attached
Reporter: jarim | Owner: grass-dev at lists.osgeo.org
Type: enhancement | Status: new
Priority: normal | Milestone: 7.0.0
Component: Display | Version: svn-trunk
Keywords: z height color zcolor | Platform: All
Cpu: x86-32 |
When you use d.vect with -z and zcolor= options the polygons are colored
based on a table of heights and colors. Looking at the source code in
display/d.vect/area.c the point (z coordinate) that is used for the color
lookup is taken from the first vertex of the area. From the user's point
of view this can appear as a random point, especially if the areas are
triangles that are created by v.delaunay. For delaunay triangles using a
single vertex does not make sense if all three points are at different
heights as can often be the case for a TIN model. The current
implementation would work in the restricted case that all area points are
at the same height.
A "good enough" and quick solution is to use a midpoint of the area
bounding box top and bottom as the z coordinate for determining the color.
A patch that implements this is attached. The centroid could be the
optimal choice for z coordinate.
The patch makes use of the bounding box of the area that is already
calculated earlier in the function. The original implementation of this z
height color functionality has unfortunately reused the same variable name
"box" for map bounding box so I renamed that one to "map_box" to make the
area bounding box available.
I have only been able to do very limited testing on Linux but this patch
seems to fix the issue that I had with my dataset.
Ticket URL: <http://trac.osgeo.org/grass/ticket/934>
