[GRASS-dev] Re: [GRASS GIS] #215: digitizer: let add attributes to category-less features
GRASS GIS trac at osgeo.org
Mon Feb 15 00:57:09 EST 2010
  Reporter:  msieczka     |       Owner:  grass-dev at lists.osgeo.org
      Type:  enhancement  |      Status:  new
  Priority:  normal       |   Milestone:  6.5.0
 Component:  wxGUI        |     Version:  svn-develbranch6
Resolution:               |    Keywords:  vdigit
  Platform:  All          |         Cpu:  All
Changes (by hamish):
  * keywords:  => vdigit
  * priority:  major => normal
  * milestone:  6.4.0 => 6.5.0
Comment:
 Replying to [ticket:215 msieczka]:
 > I suggest adding "Add a record to the table" function in the
 > "Update attributes" for cases when the feature has a category,
 > but doesn't have it's row in the table yet.
 could you explain that in more detail? (my brain is a bit sleepy right now
 and I don't know vdigit very well)
 perhaps could you explain it to me in terms of the tcl/tk v.digit which I
 am more familiar with? (thanks)
 Rather than duplicate the DB attribute manager, perhaps we could
 have a button in the vdigit toolbar that launches it? Would that need
 something that checks every now and then if it has been externally updated
 & refresh?
 > This will also allow adding attributes to category-less features
 > *during digitizing*: add a category with "Display/update
 > categories", add a row in the table for the category with
 > Display/update categories", edit the attributes.
 I agree that it could use a much smoother workflow. I am sure that this
 polish will come with time; for now I'm happy with it being basically
 functional.
 weird workflow example: it is not exactly clear to me how to digitize new
 boundaries without cat numbers. I can open the category and fumble about
 selecting and right-clicking to remove the cat, but with out a help page
 to tell me where to find it, I found it took me some time to figure out.
 Hamish
 (priority adjusted because "normal" didn't exist when ticket was created,
 milestone adjusted as 6.4.0 is in feature freeze)
Ticket URL: <https://trac.osgeo.org/grass/ticket/215#comment:1>
