[GRASS-dev] Re: [GRASS GIS] #534: g.gui doesn't work in ms-windows
trac at osgeo.org
Mon Feb 15 03:28:19 EST 2010
Reporter: cnielsen | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: reopened
Priority: major | Milestone: 6.4.0
Component: wxGUI | Version: svn-releasebranch64
Resolution: | Keywords: wingrass
Platform: MSWindows XP | Cpu: Unspecified
Comment (by glynn):
Replying to [comment:13 hamish]:
> Putting a fail-safe in g.gui.c still needs to be decided but is not a
blocker for release.
It would also need to go into lib/gis/parser.c, g.mapsets/main.c,
scripts/wxpyimgview/wxpyimgview.py, v.krige.py and d.rast.edit.py (when
they eventually get fixed), and anything else which uses $GRASS_PYTHON.
IOW, it '''needs''' to be set in the startup scripts. Adding workarounds
for specific cases is fixing the symptoms rather than the bug.
Ticket URL: <https://trac.osgeo.org/grass/ticket/534#comment:16>
