[GRASS-dev] Re: [GRASS GIS] #96: v.surf.bspline column option broken
trac at osgeo.org
Mon Feb 15 03:49:46 EST 2010
Reporter: cmbarton | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: reopened
Priority: major | Milestone: 6.4.0
Component: Raster | Version: unspecified
Resolution: | Keywords: v.surf.bspline
Platform: All | Cpu: All
Comment (by hamish):
Replying to [comment:17 cmbarton]:
> BTW, using the layer=-1 for 3D points is poor interface design.
> There should be a flag for this. It should not depend on using
> an illegal value for layers.
well, if it helps, think of it as "layer=none" in a system constrained to
integers. maybe not ideal, but not totally evil either. A programmer's
trick which has snuck into the UI..
Hamish
ps- something weird with server reboots, ldap, or something, I'm having to
re-logon into trac every hour or so the last couple of days.
Ticket URL: <https://trac.osgeo.org/grass/ticket/96#comment:18>
