[GRASS-dev] Re: [GRASS GIS] #944: menudata.py: strip out & key shortcut hint
GRASS GIS trac at osgeo.org
Tue Feb 16 05:05:00 EST 2010
  Reporter:  hamish  |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect  |      Status:  new
  Priority:  normal  |   Milestone:  7.0.0
 Component:  wxGUI   |     Version:  svn-trunk
Resolution:          |    Keywords:  menudata.py, synopsis
  Platform:  All     |         Cpu:  All
Comment (by glynn):
 Replying to [ticket:944 hamish]:
 > in source:grass/trunk/wxpython/gui_modules/menudata.py
 `__PrintCommandsItems` does not strip out "&" from the menu titles, so
 those keyboard shortcut hints get propagated into the output.
 Is there some reason why they should be stripped out?
 AFAIK, the "commands" option only exists as a convenience for developers.
 The only option which is actually used is "strings", which is used to
 generate menustrings.py (for translation).
Ticket URL: <https://trac.osgeo.org/grass/ticket/944#comment:1>
