[GRASS-dev] Re: [GRASS GIS] #944: menudata.py: strip out & key shortcut hint
GRASS GIS trac at osgeo.org
Tue Feb 16 06:29:40 EST 2010
  Reporter:  hamish  |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect  |      Status:  new
  Priority:  normal  |   Milestone:  7.0.0
 Component:  wxGUI   |     Version:  svn-trunk
Resolution:          |    Keywords:  menudata.py, synopsis
  Platform:  All     |         Cpu:  All
Comment (by hamish):
 > Is there some reason why they should be stripped out?
 yes, the menudata.py "commands" option is used to generate a list of all
 modules and their menu position in a flat ascii file for later parsing by
 the module_synopsis script. the resulting PDF and html synopses, and
 furutre module man page menu location text if full of meaningless "&"s if
 they aren't stripped out.
 menudata.py's `__PrintCommandsItems` seems the most obvious place to do it
 (as close to the source of the problem as possible), unless there are any
 i18n needs etc. wheich require them to stay.
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/944#comment:2>
