[GRASS-dev] [GRASS GIS] #949: strings.h error when compiling recent
versions of nviz
trac at osgeo.org
Wed Feb 17 09:07:08 EST 2010
#949: strings.h error when compiling recent versions of nviz
Reporter: jkaplan | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: NVIZ | Version: svn-develbranch6
Keywords: grass6_wxnviz.i, strcasecmp, fink | Platform: MacOSX
Cpu: OSX/Intel |
Hello GRASS developers,
When trying to compile recent versions of GRASS (v.6 development branch or
GRASS 7) I encountered an error during compilation of nviz related to the
function 'strcasecmp' which seems to be included through several layers of
the wxgtk libraries. Please see the command line output below.
admin at Abies:~/Downloads/grass6/grass6_devel/gui/wxpython/nviz > make
python setup.py build_ext --swig=/sw/bin/swig --swig-opts=-c++ --build-
lib=OBJ.i386-apple-darwin10.2.0 --build-temp=OBJ.i386-apple-darwin10.2.0
running build_ext
building '_grass6_wxnviz' extension
swigging grass6_wxnviz.i to grass6_wxnviz_wrap.cpp
/sw/bin/swig -python -c++ -o grass6_wxnviz_wrap.cpp grass6_wxnviz.i
gcc -fno-strict-aliasing -mno-fused-madd -DNDEBUG -g -fwrapv -O3 -Wall
-Wstrict-prototypes -DPACKAGE="grasslibs" -D_FILE_OFFSET_BITS=64
-D_LARGE_FILES -D__WXGTK__
-I/Users/admin/Downloads/grass6/grass6_devel/dist.i386-apple-
darwin10.2.0/include
-I/Library/Frameworks/GDAL.framework/Versions/1.6/Headers
-I/sw/lib/wx/include/gtk2-unicode-release-2.8 -I/sw/include/wx-2.8
-I/usr/X11/include -I/usr/X11R6/include -I/sw/include/python2.5 -c
grass6_wxnviz_wrap.cpp -o OBJ.i386-apple-darwin10.2.0/grass6_wxnviz_wrap.o
cc1plus: warning: command line option "-Wstrict-prototypes" is valid for
C/ObjC but not for C++
In file included from /sw/include/wx-2.8/wx/memory.h:16,
from /sw/include/wx-2.8/wx/object.h:20,
from /sw/include/wx-2.8/wx/wx.h:16,
from nviz.h:23,
from grass6_wxnviz_wrap.cpp:2612:
/sw/include/wx-2.8/wx/string.h: In function 'int Stricmp(const char*,
const char*)':
/sw/include/wx-2.8/wx/string.h:141: error: 'strcasecmp' was not declared
in this scope
error: command 'gcc' failed with exit status 1
make: *** [OBJ.i386-apple-darwin10.2.0/_grass6_wxnviz.so] Error 1
I am not experienced enough of a programmer to know the "right" way to
solve this problem, but I was able to make a workaround by modifying the
file grass6_devel/gui/wxpython/nviz/grass6_wxnviz.i to include the
statement #include <strings.h>
The first lines of grass6_wxnviz.i in my patched version (which does
compile) look like this:
/* File: nviz.i */
%module grass6_wxnviz
#include "nviz.h"
#include <grass/gsurf.h>
#include <grass/gstypes.h>
#undef check
etc...
Ticket URL: <http://trac.osgeo.org/grass/ticket/949>
