[GRASS-dev] [GRASS GIS] #951: Error querying rasters in wxgui
trac at osgeo.org
Wed Feb 17 09:40:15 EST 2010
Reporter: epatton | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 6.5.0
Component: wxGUI | Version: svn-develbranch6
Keywords: query, gui, wxpython | Platform: Linux
Cpu: x86-64 |
In the North Carolina dataset, load the elevation raster into the Layer
Manager and then use the query raster/vector maps tool from the Map
Display window to query the elevation raster, which gives the following
error:
Exception in thread Thread-1:
File "/usr/lib/python2.6/threading.py", line 525, in
__bootstrap_inner
self.run()
File "/usr/local/grass-6.5.svn/etc/wxpython/gui_modules/go
utput.py", line 108, in run
moduleInterface = menuform.GUI().ParseCommand(args[0],
show = None)
File "/usr/local/grass-6.5.svn/etc/wxpython/gui_modules/me
nuform.py", line 1782, in ParseCommand
self.grass_task.set_flag(option[2:], True)
nuform.py", line 373, in set_flag
param = self.get_flag(aFlag)
nuform.py", line 367, in get_flag
raise ValueError, _("Flag not found: %s") % aFlag
ValueError: Flag not found: q
The full command printed to the Output window is:
r.what --q -f input=elevation at PERMANENT
east_north=632293.445122,224363.567073
~ Eric
Ticket URL: <http://trac.osgeo.org/grass/ticket/951>
