[GRASS-dev] Re: [GRASS GIS] #950: Error opening workspace file
trac at osgeo.org
Tue Feb 23 19:29:31 EST 2010
Reporter: epatton | Owner: martinl
Type: defect | Status: assigned
Priority: normal | Milestone: 6.5.0
Component: wxGUI | Version: svn-develbranch6
Resolution: | Keywords: gui, workspace
Platform: Linux | Cpu: x86-64
Comment (by epatton):
Thanks Martin, I can confirm nested folders retain their positions after
reopening workspace files.
Can you confirm this behavior - I'm not sure what is happening here - if
you have a folder with a few layers inside, and drag the folder's position
around so it is above or below other folders or layers in the layer
manager, a layer always seems to get dropped from the folder after the
move is completed.
Should I file this under another bug?
~ Eric.
Ticket URL: <http://trac.osgeo.org/grass/ticket/950#comment:6>
