[GRASS-dev] Re: [GRASS GIS] #928: 6.4: all shell scripts broken
from command line + tcl; wx addon scripts broken
trac at osgeo.org
Thu Feb 18 04:16:59 EST 2010
#928: 6.4: all shell scripts broken from command line + tcl; wx addon scripts
broken
Reporter: hamish | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: blocker | Milestone: 6.4.0
Component: default | Version: svn-releasebranch64
Resolution: | Keywords: addons
Platform: Linux | Cpu: x86-64
Comment (by glynn):
Replying to [comment:1 hamish]:
> I guess it has to do with this, but unless popen() has different quoting
needs I don't see the difference:
> r40849 (relbr64) `Replace G_popen() with popen() (backport from devbr6,
r40834)`
> does this need to be backported to 6.x?:
> r40904 (trunk) `G_spawn_ex() expects descriptors as "int"s, not
"char*".`
It can't be; the code which it fixes doesn't exist in 6.4 (and isn't
actually used in 6.5, and probably shouldn't have been back-ported).
But that's not the problem here. The problem is r40716, which back-ports
r40713. This was fixed in 6.5 with r40724, which also needs to be back-
ported.
The various "popen"-related issues which appear to be getting conflated
are:
1. The [G_]popen() of $GRASS_WISH for the parameter dialogs. Originally,
$GRASS_WISH wasn't quoted, which may create problems on Windows if it's
somewhere within `$ProgramFiles`. So r40713 quotes it, but I screwed up
(the Unix version used single quotes instead of double quotes, and wasn't
tested). This was fixed in r40724. It isn't applicable to 7.0, as
GRASS_GUI=tcltk isn't supported there.
2. Eliminating (the old) G_popen() in favour of popen(). G_popen() just
mimics popen() on Unix and doesn't work on Windows (which actually
provides a Unix-style popen()).
3. In 7.0, G_popen() is implemented on top of G_spawn_ex() and has a
completely different interface: it accepts an argument list (char**)
rather than a string to be interpreted by the shell. Currently, it's only
used by G_pager() (interface to $GRASS_PAGER) and the code which emails
error messages to the user. In 6.x, it isn't used at all; with popen()
being eliminated, lib/gis/popen.c can (and should) be removed.
Ticket URL: <https://trac.osgeo.org/grass/ticket/928#comment:2>
