[GRASS-dev] MODIS Metadata information kept after GDALimport/warp
into GRASS
António Rocha
antonio.rocha at deimos.com.pt
Thu Feb 18 04:35:12 EST 2010
Those hist files only include the operations that are performed inside
GRASS. But for instance, MERIS-ENVISAT and other EO data includes GAIN,
SCALEFACTOR and other parameter that are relevant for image processing.
When I import them to GRASS how can I maintain this information in
raster header?
Or isn't possible and I only can do that, by inserting text using
r.support, when images are already imported to GRASS?
Thank you Hamish
> Hamish wrote:
> you can add it one line at a time with "r.support history=".
> Officially you are limited to 50 lines 80chars long, but maybe you
> could push that? You can then view it with r.info.
> this is stored in the $MAPSET/hist/$MAPNAME text file.
> It is planned that the raster meta-data support will be significantly
> upgraded when we cleanup the raster format for grass 7.
>> I'm importing MODIS datasets (HDF4 format) using Method 1
>> from http://grass.osgeo.org/wiki/MODIS#Import.
>> My question is related with the extensive metadata. How can
>> I kept this metadata associated with file after it's
>> imported to GRASS? I don't want to loose that precious
>> information. Is it possible?
__________ Information from ESET NOD32 Antivirus, version of virus signature database 4875 (20100217) __________
The message was checked by ESET NOD32 Antivirus.
http://www.eset.com
