[GRASS-dev] MODIS Metadata information kept after GDALimport/warp into GRASS
Markus Neteler neteler at osgeo.org
Thu Feb 18 04:48:22 EST 2010
2010/2/18 António Rocha <antonio.rocha at deimos.com.pt>:
> Those hist files only include the operations that are performed inside
> GRASS. But for instance, MERIS-ENVISAT and other EO data includes GAIN,
> SCALEFACTOR and other parameter that are relevant for image processing. When
> I import them to GRASS how can I maintain this information in raster header?
> Or isn't possible and I only can do that, by inserting text using r.support,
> when images are already imported to GRASS?
Yes, exactly.
I am extracting the metadata from the XML file, then import MODIS, then
add the metadata with r.support. No big deal...
Markus
