[GRASS-dev] MODIS Metadata information kept after GDALimport/warp into GRASS
António Rocha antonio.rocha at deimos.com.pt
Thu Feb 18 05:05:31 EST 2010
If you put it like that it seems easy :). How are you parsing metadata
to an XML file?
Markus Neteler wrote:
> 2010/2/18 António Rocha <antonio.rocha at deimos.com.pt>:
>> Those hist files only include the operations that are performed inside
>> GRASS. But for instance, MERIS-ENVISAT and other EO data includes GAIN,
>> SCALEFACTOR and other parameter that are relevant for image processing. When
>> I import them to GRASS how can I maintain this information in raster header?
>> Or isn't possible and I only can do that, by inserting text using r.support,
>> when images are already imported to GRASS?
> Yes, exactly.
> I am extracting the metadata from the XML file, then import MODIS, then
> add the metadata with r.support. No big deal...
> Markus
> __________ Information from ESET NOD32 Antivirus, version of virus signature database 4876 (20100218) __________
> The message was checked by ESET NOD32 Antivirus.
> http://www.eset.com
http://www.eset.com
