[GRASS-dev] wxGUI broken in grass64 r41104
Thu Feb 18 19:57:18 EST 2010
Markus Neteler wrote:
> Try r41105.
> I have reverted gettext addition due to compile error in that file.
During the build process, menudata.py is executed as a script (with
GISBASE unset, hence the error) to generate the menustrings.py file
(so that "make -C locale pot" includes the label and help strings from
menudata.xml).
When used in this way, the strings shouldn't be translated; otherwise
you'll end up with the translated strings as "source" strings in the
grasswxpy.pot file.
