[GRASS-dev] wxGUI broken in grass64 r41104
Markus Neteler neteler at osgeo.org
Fri Feb 19 04:24:59 EST 2010
On Fri, Feb 19, 2010 at 1:57 AM, Glynn Clements
<glynn at gclements.plus.com> wrote:
> Markus Neteler wrote:
>> Try r41105.
>> I have reverted gettext addition due to compile error in that file.
> During the build process, menudata.py is executed as a script (with
> GISBASE unset, hence the error) to generate the menustrings.py file
> (so that "make -C locale pot" includes the label and help strings from
> menudata.xml).
> When used in this way, the strings shouldn't be translated; otherwise
> you'll end up with the translated strings as "source" strings in the
> grasswxpy.pot file.
I'll leave needed corrections (if any) to the wx/python-savvy people.
Markus
