[GRASS-dev] wxGUI broken in grass64 r41104
Markus Metz markus.metz.giswork at googlemail.com
Fri Feb 19 04:28:48 EST 2010
Markus Neteler wrote:
> On Thu, Feb 18, 2010 at 11:37 PM, Markus Metz
> <markus.metz.giswork at googlemail.com> wrote:
>> running make in gui/wypython in grass64 gives me
>> Traceback (most recent call last):
>>  File "gui_modules/menudata.py", line 76, in <module>
>>   gettext.install('grasswxpy', os.path.join(os.getenv("GISBASE"), 'locale'),
>> unicode=True)
>>  File "/usr/lib64/python2.5/posixpath.py", line 62, in join
>>   elif path == '' or path.endswith('/'):
>> AttributeError: 'NoneType' object has no attribute 'endswith'
>> make[1]: *** [menustrings.py] Error 1
>> make: *** [install_scripts] Error 2
>> after make distclean, configuring anew, make
> Try r41105.
Thanks, everything compiles fine now.
