[GRASS-dev] Re: [GRASS GIS] #945: wxGUI: g.setproj fails on wingrass
GRASS GIS trac at osgeo.org
Sat Feb 20 08:59:32 EST 2010
  Reporter:  hamish        |       Owner:  martinl
      Type:  defect        |      Status:  assigned
  Priority:  major         |   Milestone:  6.4.0
 Component:  wxGUI         |     Version:  svn-releasebranch64
Resolution:                |    Keywords:  g.setproj, wingrass
  Platform:  MSWindows XP  |         Cpu:  x86-32
Comment (by hamish):
 with the 6.4 nightly wingrass binary r41114 wxGUI, I get this error popup
 when I try to start g.setproj from the Config->Manage projections menu:
 __ \"c:/Program Files/GRASS-64-SVN\etc\grass-run.bat\" __
 Windows cannot find "\"c:Program Files/GRASS-64-SVN\etc\grass-run.bat\"".
 Make sure you typed the name correctly, and then try again.
 To search for a file, click the Start button, and then click
 Search.
 [Ok]
 from the MSys terminal prompt I correctly get the "You must be in the
 PERMANENT mapset to run this" error message; from the wxGUI Cmd> prompt I
 get the popup module auto-GUI but nothing at all happens when I click
 [Run].
 from the GIS.m tcl gui it flashes open a DOS box with the "you must be in
 PERMANENT.." error and a beep, and then after 250ms the dosbox closes
 again. You just have time to read the error message.
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/945#comment:3>
