[GRASS-dev] Re: [GRASS GIS] #945: wxGUI: g.setproj fails on wingrass
trac at osgeo.org
Sat Feb 20 11:58:50 EST 2010
Reporter: hamish | Owner: martinl
Type: defect | Status: assigned
Priority: major | Milestone: 6.4.0
Component: wxGUI | Version: svn-releasebranch64
Resolution: | Keywords: g.setproj, wingrass
Platform: MSWindows XP | Cpu: x86-32
Comment (by glynn):
Replying to [comment:3 hamish]:
> with the 6.4 nightly wingrass binary r41114 wxGUI, I get this error
popup when I try to start g.setproj from the Config->Manage projections
menu:
__ \"c:/Program Files/GRASS-64-SVN\etc\grass-run.bat\" __
Windows cannot find "\"c:Program Files/GRASS-64-SVN\etc\grass-run.bat\"".
IOW, OnXTerm() is still as broken as it always was. In particular, I note:
cmdlist = ["cmd.exe", "/c", 'start "%s"' % runbat, command]
Try using:
cmdlist = ["start", runbat, command]
then running the command with shell=True (if this isn't already set, which
it should be).
Also try not using gcmd.Command(). It appears to be intended to run GRASS
commands, and neither cmd.exe nor start are GRASS commands. It's also
insanely hard to figure out what's going on once you get into
gcmd.Command().
Ticket URL: <https://trac.osgeo.org/grass/ticket/945#comment:4>
