[GRASS-dev] Re: grass-dev Digest, Vol 46, Issue 94
Michael Barton
michael.barton at asu.edu
Tue Feb 23 12:10:35 EST 2010
Thanks very much Moritz,
It's really good that you have been able to do this even with all the other things needed at the *real* job.
I know how it goes sometimes. I wasn't able to do much for over a year. Now I'm facing similar time crunches in the immediate future.
Michael
On Feb 23, 2010, at 10:00 AM, grass-dev-request at lists.osgeo.org wrote:
> Date: Tue, 23 Feb 2010 13:12:20 +0000 (UTC)
> From: Moritz Lennert <mlennert at club.worldonline.be>
> Subject: [GRASS-dev] Re: d.vect.thematic
> To: grass-dev at lists.osgeo.org
> Message-ID: <loom.20100223T135518-817 at post.gmane.org>
> Content-Type: text/plain; charset=us-ascii
> Michael Barton <Michael.Barton <at> asu.edu> writes:
>> I agree with Martin...I think. But maybe rewriting the current script and
> getting rid of the xmon stuff
>> would get us 90% of the way there. I'm wondering if what should be done is to
> just rewrite the point/line
>> parts of the script and leave the choropleth maps to d.thematic.area.
> d.thematic.area has a few rough
>> edges, but overall it is a powerful tool.
>> A reason to make a script that includes the point/line thematic mapping AND
> wraps d.thematic.area into one
>> tool is to get the legend. Currently d.thematic.area writes d.graph
> instructions for the legend. A
>> script could grab those and turn them into a nice legend in a wxPython
>> canvas.
> Or, I suppose we could just
>> write a separate script to do that.
> Sorry, I had to make priorities at work and have been very absent from
> grass-dev in the last year. I'll try to find some time to be a bit more present
> in the future.
> Concerning d.thematic.area/line/point: It's good that d.thematic.area is
> finally tested a bit. I know it is still in beta state at best, but I hope that
> someone a bit knowledgeable can fairly quickly smooth out some of the rough
> edges.
> Over half a year ago I mentioned that I had actually started working on
> d.thematic.linepoint (name open to discussion obviously ;-) ), but that it
> still needed work. Unfortunately, I have not found the time to touch it since
> (the problem being that I normally need a few days in a row to really get into
> the programming mode again). Martin suggested I post the code as is to svn, but
> I was a bit hesitant as I think it needs a bit more work before it can be
> shared. I will see if I can find time this week to work on it, otherwise I'll
> just submit the code as is...
> Moritz
