[GRASS-dev] Re: [GRASS GIS] #303: new ffmpeg includes layout
trac at osgeo.org
Wed Feb 24 10:20:46 EST 2010
Reporter: kyngchaos | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 6.5.0
Component: Compiling | Version: svn-develbranch6
Resolution: | Keywords:
Platform: All | Cpu: All
Changes (by kyngchaos):
* priority: major => normal
* component: Raster => Compiling
* milestone: 6.4.0 => 6.5.0
Comment:
A couple followup notes:
- March 2009 a source package of ffmpeg was released, so the new layout
should be much more common now since system
packagers will more likely include a defined release. I think we should
support the new layout directly. Specifying ''all'' the lib* folders does
work, but it's annoying and not obvious to users who simply want to build
GRASS.
- For the static lib linking and configure test problems, the simple
solution is to use shared libraries. It works, though there's a little
more bundling to do in the packaging stage (though that's not a problem
for the average user).
Ticket URL: <http://trac.osgeo.org/grass/ticket/303#comment:10>
