[GRASS-dev] [GRASS GIS] #967: r.out.png: respect TRANSPARENT and COMPRESSION enviro vars
GRASS GIS trac at osgeo.org
Fri Feb 26 07:27:48 EST 2010
 Reporter:  hamish       |       Owner:  grass-dev at lists.osgeo.org
     Type:  enhancement  |      Status:  new
 Priority:  normal       |   Milestone:  7.0.0
Component:  Raster       |     Version:  svn-trunk
 Keywords:  r.out.png    |    Platform:  All
      Cpu:  All          |
 Peter Löwe discovered that r.out.png does not respect GRASS_TRANSPARENT or
 GRASS_PNG_COMPRESSION, which limits the module's usefulness.  (especially
 the lack of NULL->alpha)
 I'm guessing we should have it respect both GRASS_TRANSPARENT and a module
 flag, if they conflict I guess go with the enviro variable.
 Same for compression with a module option=1-9.
 a work-around for now is to use the PNG driver with GRASS_WIDTH and HEIGHT
 taken from the image meta data.
 thanks,
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/967>
