[GRASS-dev] Re: [GRASS GIS] #967: r.out.png: respect TRANSPARENT and
COMPRESSION enviro vars
trac at osgeo.org
Fri Feb 26 15:11:23 EST 2010
#967: r.out.png: respect TRANSPARENT and COMPRESSION enviro vars
Reporter: hamish | Owner: grass-dev at lists.osgeo.org
Type: enhancement | Status: new
Priority: normal | Milestone: 7.0.0
Component: Raster | Version: svn-trunk
Resolution: | Keywords: r.out.png
Platform: All | Cpu: All
Comment (by glynn):
Replying to [ticket:967 hamish]:
> Peter Löwe discovered that r.out.png does not respect GRASS_TRANSPARENT
or GRASS_PNG_COMPRESSION, which limits the module's usefulness.
(especially the lack of NULL->alpha)
> I'm guessing we should have it respect both GRASS_TRANSPARENT and a
module flag, if they conflict I guess go with the enviro variable.
> Same for compression with a module option=1-9.
You guessed wrong ;)
GRASS_TRANSPARENT and GRASS_PNG_COMPRESSION are for the display drivers,
which don't have the option of reading parameters from the command-line,
so they have to use environment variables instead.
r.out.png should use command-line options; it shouldn't be looking at
environment variables.
While you're at it, there are a dozen or so other parameters which could
reasonably be set by command-line options.
Ticket URL: <https://trac.osgeo.org/grass/ticket/967#comment:1>
