[GRASS-dev] Re: [GRASS GIS] #967: r.out.png: respect TRANSPARENT and
COMPRESSION enviro vars
trac at osgeo.org
Fri Feb 26 22:42:46 EST 2010
#967: r.out.png: respect TRANSPARENT and COMPRESSION enviro vars
Reporter: hamish | Owner: grass-dev at lists.osgeo.org
Type: enhancement | Status: new
Priority: normal | Milestone: 7.0.0
Component: Raster | Version: svn-trunk
Resolution: | Keywords: r.out.png
Platform: All | Cpu: All
Comment (by hamish):
patch attached to add transparency, compression, and background color
options to r.out.png. Patch is vs 6.5svn.
* I'm not sure how useful bgcolor= is, as I'm not sure how often "set" is
likely to return no-color from G_lookup_raster_colors(), or really what
triggers that to be set==0. Or should bgcolor= override the color table's
"nv" color for NULL cells when there's no alpha channel? Is "set" like the
default("*") lesser used rule in the color tables?
* the pointer for G_is_null_value() is specified in a rather raw way.
Ideas for improvement are welcome.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/967#comment:2>
