[GRASS-dev] Re: [GRASS GIS] #660: v.delaunay producing incorrect results
GRASS GIS trac at osgeo.org
Sat Jan 2 07:10:40 EST 2010
  Reporter:  cmbarton  |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect    |      Status:  new
  Priority:  critical  |   Milestone:  6.4.0
 Component:  Vector    |     Version:  6.4.0 RCs
Resolution:            |    Keywords:  delaunay
  Platform:  MacOSX    |         Cpu:  OSX/Intel
Comment (by marisn):
 Replying to [comment:16 mmetz]:
 > Please try attached patch in verbose mode.
 > Markus M
 On my Linux box still works just fine. Only question is regarding this
 warning. Is it OK to ignore?
 ==10913== Syscall param write(buf) points to uninitialised byte(s)
 ==10913==    at 0x749D210: __write_nocancel (syscall-template.S:82)
 ==10913==    by 0x7447422: _IO_file_write@@GLIBC_2.2.5 (fileops.c:1268)
 ==10913==    by 0x7447099: new_do_write (fileops.c:522)
 ==10913==    by 0x74473C4: _IO_do_write@@GLIBC_2.2.5 (fileops.c:495)
 ==10913==    by 0x7448CC6: _IO_switch_to_get_mode (genops.c:189)
 ==10913==    by 0x7447AB7: _IO_file_seekoff@@GLIBC_2.2.5 (fileops.c:978)
 ==10913==    by 0x743CD0B: ftell (ioftell.c:41)
 ==10913==    by 0x5D22F8B: dig__write_head (head.c:56)
 ==10913==    by 0x4E568BE: V1_open_new_nat (open_nat.c:127)
 ==10913==    by 0x4E55A7B: Vect_open_new (open.c:565)
 ==10913==    by 0x40309B: main (main.c:106)
 ==10913==  Address 0x4036009 is not stack'd, malloc'd or (recently) free'd
Ticket URL: <http://trac.osgeo.org/grass/ticket/660#comment:21>
