[GRASS-dev] Re: [GRASS GIS] #660: v.delaunay producing incorrect
results
trac at osgeo.org
Sat Jan 2 08:54:40 EST 2010
#660: v.delaunay producing incorrect results
Reporter: cmbarton | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: critical | Milestone: 6.4.0
Component: Vector | Version: 6.4.0 RCs
Resolution: | Keywords: delaunay
Platform: MacOSX | Cpu: OSX/Intel
Comment (by mmetz):
Replying to [comment:21 marisn]:
> Replying to [comment:16 mmetz]:
> > Please try attached patch in verbose mode.
> > Markus M
> On my Linux box still works just fine. Only question is regarding this
warning. Is it OK to ignore?
==10913== Syscall param write(buf) points to uninitialised byte(s)
==10913== at 0x749D210: __write_nocancel (syscall-template.S:82)
==10913== by 0x7447422: _IO_file_write@@GLIBC_2.2.5 (fileops.c:1268)
==10913== by 0x7447099: new_do_write (fileops.c:522)
==10913== by 0x74473C4: _IO_do_write@@GLIBC_2.2.5 (fileops.c:495)
==10913== by 0x7448CC6: _IO_switch_to_get_mode (genops.c:189)
==10913== by 0x7447AB7: _IO_file_seekoff@@GLIBC_2.2.5 (fileops.c:978)
==10913== by 0x743CD0B: ftell (ioftell.c:41)
==10913== by 0x5D22F8B: dig__write_head (head.c:56)
==10913== by 0x4E568BE: V1_open_new_nat (open_nat.c:127)
==10913== by 0x4E55A7B: Vect_open_new (open.c:565)
==10913== by 0x40309B: main (main.c:106)
==10913== Address 0x4036009 is not stack'd, malloc'd or (recently) free'd
This warning is a complete mystery to me, it shows up with some vector
modules but not with others, therefore I would say it is safe to ignore.
The beginning of v.delaunay is nearly identical with v.voronoi, but
v.voronoi does not show this warning?
AFAICT, this warning appears because the file pointer for the coor file
points to the end of the coor file (uninitialised bytes), but that's what
it's supposed to do.
Markus M
Ticket URL: <https://trac.osgeo.org/grass/ticket/660#comment:22>
