[GRASS-dev] Issues of 6.5 build on WinXP
Martin Landa landa.martin at gmail.com
Sat Jan 2 09:45:42 EST 2010
2009/12/28 Glynn Clements <glynn at gclements.plus.com>:
>> Not sure what is wrong...
> First, ensure that you have GNU make 3.81; I wouldn't trust older
> versions to handle non-trivial use of "eval".
> FWIW, the locale directory from GRASS 6.5 builds fine for me on
> Windows (with make 3.81).
right, it was cased by the fact that I was using make < 3.81. Thanks, Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
