[GRASS-dev] Issues of 6.5 build on WinXP
Martin Landa
landa.martin at gmail.com
Sat Jan 2 09:48:08 EST 2010
2009/12/28 Jan Tošovský <j.tosovsky at tiscali.cz>:
> 1) I cannot add a new vector map layer. Only a dummy one is added without
> the standard option dialog. All corresponding messages from the Command
> output tab can be found at the bottom of this e-mail. Raster maps are Ok.
I commented out problematic code in r40191. Now should work.
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
