[GRASS-dev] Connection failure from v.krige to R (Win XP)
Jan Tošovský j.tosovsky at tiscali.cz
Sat Jan 2 13:51:27 EST 2010
Several times I also met another Kriging issue. When entering the Kriging
dialog when a vector map was selected before this action via menu, I am
getting the following error and execution is stopped (no dialog appears)
v.krige input=isolines at honza
ERROR: Required parameter <column> was not set:
(Name of attribute column with numerical value to be interpolated).
Description:
 Performs ordinary or block kriging.
Keywords:
(parameters info continues)
Maybe it is on purpose to process the selected map, (and that selected map
wasn't suited for this operation), but I would prefer selecting in the
dialog.
As this cannot be reproduced even with the same procedure later, I rather
think it could be a bug when something in the background is improperly
initialized.
Regards,
Jan
