[GRASS-dev] Issues of 6.5 build on WinXP
Michael Barton
michael.barton at asu.edu
Sat Jan 2 17:06:14 EST 2010
On Jan 2, 2010, at 10:00 AM, grass-dev-request at lists.osgeo.org wrote:
> Date: Sat, 2 Jan 2010 15:48:08 +0100
> From: Martin Landa <landa.martin at gmail.com>
> Subject: Re: [GRASS-dev] Issues of 6.5 build on WinXP
> To: Jan To?ovsk? <j.tosovsky at tiscali.cz>
> Cc: grass-dev at lists.osgeo.org
> Message-ID:
> <f8fe65c41001020648o5ecb5878l88084ad793d2267b at mail.gmail.com>
> Content-Type: text/plain; charset=ISO-8859-2
> Hi,
> 2009/12/28 Jan To?ovsk? <j.tosovsky at tiscali.cz>:
>> 1) I cannot add a new vector map layer. Only a dummy one is added without
>> the standard option dialog. All corresponding messages from the Command
>> output tab can be found at the bottom of this e-mail. Raster maps are Ok.
> I commented out problematic code in r40191. Now should work.
> Martin
Glynn, Jan,
Do these changes and those in r40191-40200 fix the lag on adding a vector? Can you check?
Thanks
Michael
