[GRASS-dev] xganim compilation on GRASS 7
William Kyngesburye woklist at kyngchaos.com
Sun Jan 3 13:36:05 EST 2010
This is the part:
> c++ -L/Users/cmbarton/grass_dev/grass70_dev/dist.i386-apple-darwin10.2.0/lib -L/Users/cmbarton/grass_dev/grass70_dev/dist.i386-apple-darwin10.2.0/lib       -o /Users/cmbarton/grass_dev/grass70_dev/dist.i386-apple-darwin10.2.0/bin/xganim OBJ.i386-apple-darwin10.2.0/gui.o OBJ.i386-apple-darwin10.2.0/main.o  -lgrass_raster -lgrass_gis -L/usr/local/lib/wxPython-unicode-2.8.10.1/lib   -framework IOKit -framework Carbon -framework Cocoa -framework System -framework QuickTime -framework OpenGL -framework AGL  -lwx_macud-2.8
> ld: warning: in /System/Library/Frameworks//QuickTime.framework/QuickTime, missing required architecture x86_64 in file
> ld: warning: in /usr/local/lib/wxPython-unicode-2.8.10.1/lib/libwx_macud-2.8.dylib, missing required architecture x86_64 in file
The missing symbol errors were because of the missing arch error.  xganim is not getting the arch magic, so is building 64bit by default, which doesn't work for wxpython.  Interesting that Quicktime is missing the 64bit arch (same on my Mac), maybe it's because that's the old Quicktime 7.x, and the new Quicktime X is somewhere else...
I'll look at the xganim makefile and try to fix it later today.
On Jan 3, 2010, at 12:15 PM, Michael Barton wrote:
> VERY long command, if I read this correctly. So I'm attaching it as a text file.
> Michael
> <xganim_error.txt>
> On Jan 3, 2010, at 11:00 AM, William Kyngesburye wrote:
>> What's the complete compile command just before that error?
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"Time is an illusion - lunchtime doubly so."
- Ford Prefect
