[GRASS-dev] xganim compilation on GRASS 7
Helena Mitasova hmitaso at unity.ncsu.edu
Sun Jan 3 14:40:27 EST 2010
William,
talking about xganim, will you be including xganim in your GRASS64
binaries?
We use it a lot for viewing and browsing the results of simulations
and data time series
on our linux machines but the students miss it on Mac and MSwindows.
Also, do you plan to make the wxpython GUI the default as it is in
the windows binaries?
thank you,
Helena
On Jan 3, 2010, at 1:36 PM, William Kyngesburye wrote:
> This is the part:
>> c++ -L/Users/cmbarton/grass_dev/grass70_dev/dist.i386-apple-
>> darwin10.2.0/lib -L/Users/cmbarton/grass_dev/grass70_dev/dist.i386-
>> apple-darwin10.2.0/lib       -o /Users/cmbarton/grass_dev/
>> grass70_dev/dist.i386-apple-darwin10.2.0/bin/xganim OBJ.i386-apple-
>> darwin10.2.0/gui.o OBJ.i386-apple-darwin10.2.0/main.o  -
>> lgrass_raster -lgrass_gis -L/usr/local/lib/wxPython-
>> unicode-2.8.10.1/lib   -framework IOKit -framework Carbon -
>> framework Cocoa -framework System -framework QuickTime -framework
>> OpenGL -framework AGL  -lwx_macud-2.8
>> ld: warning: in /System/Library/Frameworks//QuickTime.framework/
>> QuickTime, missing required architecture x86_64 in file
>> ld: warning: in /usr/local/lib/wxPython-unicode-2.8.10.1/lib/
>> libwx_macud-2.8.dylib, missing required architecture x86_64 in file
> The missing symbol errors were because of the missing arch error.
> xganim is not getting the arch magic, so is building 64bit by
> default, which doesn't work for wxpython.  Interesting that
> Quicktime is missing the 64bit arch (same on my Mac), maybe it's
> because that's the old Quicktime 7.x, and the new Quicktime X is
> somewhere else...
> I'll look at the xganim makefile and try to fix it later today.
> On Jan 3, 2010, at 12:15 PM, Michael Barton wrote:
>> VERY long command, if I read this correctly. So I'm attaching it
>> as a text file.
>> Michael
>> <xganim_error.txt>
>> On Jan 3, 2010, at 11:00 AM, William Kyngesburye wrote:
>>> What's the complete compile command just before that error?
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "Time is an illusion - lunchtime doubly so."
> - Ford Prefect
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
