[GRASS-dev] [GRASS GIS] #854: g.extension does not work on a Mac
(probably not on Windows either
trac at osgeo.org
Sun Jan 3 16:54:41 EST 2010
#854: g.extension does not work on a Mac (probably not on Windows either
Reporter: cmbarton | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Installation | Version: svn-trunk
Keywords: extensions, addons | Platform: All
Cpu: OSX/Intel |
g.extension does not work on a Mac. It seems to assume that GRASS is being
run from a source directory and tries to drop the files into the grass.app
rather than the source. So it gets a no make target error.
It needs to ask where the source directory is located, put the source
files there, and run make, followed by make install.
The manual should also clearly indicate that a successfully compiled GRASS
source distribution is required in order for this to work.
The error is below using v.strahler as an example:
g.extension extension=v.strahler svnurl=https://svn.osgeo.org/grass/grass-
addons/ prefix=/Library/Application\ Support/GRASS/7.0
menuitem=Vector;Stream order
'/Library/Application\ Support/GRASS/7.0' created
Fetching 'v.strahler' from GRASS-Addons SVN (be patient)...
A v.strahler/v.mainchannel
A v.strahler/v.mainchannel.html
A v.strahler/forest2tree.c
A v.strahler/description.html
A v.strahler/r.strahler.sh
A v.strahler/helper.c
A v.strahler/r.strahler.sh.html
A v.strahler/images
A v.strahler/images/at_rbroscoe.jpg
A v.strahler/images/Qgisout_vstrahler.jpg
A v.strahler/images/thrVScell.jpg
A v.strahler/images/wt_rbroscoe.jpg
A v.strahler/images/input_vstrahler.jpg
A v.strahler/images/menotre.jpg
A v.strahler/images/output_vstrahler.jpg
A v.strahler/images/lr_rbroscoe.jpg
A v.strahler/main.c
A v.strahler/r.broscoe.sh
A v.strahler/strahler.c
A v.strahler/r.broscoe.sh.html
A v.strahler/documentation
A v.strahler/documentation/r.broscoe_flowchart.dia
A v.strahler/documentation/v.strahler_flowchart.jpeg
A v.strahler/documentation/r.broscoe_flowchart.jpeg
A v.strahler/documentation/v.strahler_flowchart.dia
A v.strahler/strahler.h
A v.strahler/write.c
A v.strahler/Makefile
Checked out revision 40210.
Compiling 'v.strahler'...
/Applications/Grass/GRASS-7.0.app/Contents/MacOS/include/Mak
e/Rules.make:16: warning: overriding commands for target
`/Users/cmbarton/grass_dev/grass70_dev/dist.i386-apple-
darwin10.2.0'
e/Rules.make:16: warning: ignoring old commands for target
darwin10.2.0'
`/Users/cmbarton/grass_dev/grass70_dev/bin.i386-apple-
darwin10.2.0'
darwin10.2.0'
darwin10.2.0/include/grass'
darwin10.2.0/lib'
darwin10.2.0/lib'
darwin10.2.0/bin'
darwin10.2.0/bin'
darwin10.2.0/etc'
darwin10.2.0/etc'
darwin10.2.0/driver'
darwin10.2.0/driver/db'
darwin10.2.0/fonts'
darwin10.2.0/fonts'
darwin10.2.0/docs'
darwin10.2.0/docs'
darwin10.2.0/docs/html'
darwin10.2.0/man'
darwin10.2.0/man'
darwin10.2.0/man/man1'
darwin10.2.0/tools'
darwin10.2.0/tools'
e/Rules.make:19: warning: overriding commands for target
`OBJ.i386-apple-darwin10.2.0'
e/Rules.make:19: warning: ignoring old commands for target
e/Rules.make:41: warning: overriding commands for target
`clean'
e/Rules.make:41: warning: ignoring old commands for target
`clean'
make: *** No rule to make target
darwin10.2.0/docs/html/.html', needed by `html'. Stop.
ERROR: Compilation failed, sorry. Please check above error messages.
(Sun Jan 3 14:46:24 2010) Command finished (20 sec)
Ticket URL: <http://trac.osgeo.org/grass/ticket/854>
