[GRASS-dev] Re: [GRASS GIS] #854: g.extension does not work on a
Mac (probably not on Windows either
trac at osgeo.org
Sun Jan 3 17:37:58 EST 2010
#854: g.extension does not work on a Mac (probably not on Windows either
Reporter: cmbarton | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Installation | Version: svn-trunk
Resolution: | Keywords: extensions, addons
Platform: All | Cpu: OSX/Intel
Comment (by kyngchaos):
Replying to [ticket:854 cmbarton]:
> It needs to ask where the source directory is located, put the source
files there, and run make, followed by make install.
> The manual should also clearly indicate that a successfully compiled
GRASS source distribution is required in order for this to work.
I believe the intent is to NOT require a built source dir, or source at
all. It's likely that work is needed so that the installed platform.make
has the install paths instead of the original build paths, OR that it
overrides GRASS_HOME and RUN_GISBASE when running make (better, since the
install path could change).
> g.extension extension=v.strahler svnurl=https://svn.osgeo.org/grass/
grass-addons/ prefix=/Library/Application\ Support/GRASS/7.0
menuitem=Vector;Stream order
Note: the correct OSX addons dir is /Library/Application
Support/GRASS/7.0/Modules.
Ticket URL: <http://trac.osgeo.org/grass/ticket/854#comment:1>
