[GRASS-dev] Re: [GRASS GIS] #854: g.extension does not work on a
Mac (probably not on Windows either
trac at osgeo.org
Sun Jan 3 18:52:44 EST 2010
#854: g.extension does not work on a Mac (probably not on Windows either
Reporter: cmbarton | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Installation | Version: svn-trunk
Resolution: | Keywords: extensions, addons
Platform: All | Cpu: OSX/Intel
Comment (by hamish):
Replying to [comment:1 kyngchaos]:
> Replying to [ticket:854 cmbarton]:
> > g.extension extension=v.strahler svnurl=https://svn.osgeo.org/grass/
grass-addons/ prefix=/Library/Application\ Support/GRASS/7.0
menuitem=Vector;Stream order
> Note: the correct OSX addons dir is /Library/Application
Support/GRASS/7.0/Modules.
In 6.5svn I've just checked in an update which quotes all variables and it
should work better when there are spaces in pathnames now.
specifically, ${} is not enough to protect against spaces when used as a
command line argument.
this makes two directories, a/ and path/
foo="a path"
mkdir ${foo}
ls
rmdir $foo
(I'll merge it to the other branches this evening once I get the chance)
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/854#comment:2>
