[GRASS-dev] xganim compilation on GRASS 7
Michael Barton
Michael.Barton at asu.edu
Sun Jan 3 20:48:19 EST 2010
On Jan 3, 2010, at 3:22 PM, William Kyngesburye wrote:
> On Jan 3, 2010, at 3:32 PM, Michael Barton wrote:
>> On Jan 3, 2010, at 2:13 PM, William Kyngesburye wrote:
>> I'm specifying the archs, using the exact same config string that I used successfully a couple days ago. This string works in 6.5 too. Could this be related to the Mac make file changes you did over the last couple days?
>> Michael
> I thought you were, but this is exactly what would happen if not...
> In platform.make, what do you have for
> LINK_FLAGS
LINK_FLAGS = -arch i386 -arch x86_64
> MACOSX_ARCHS
MACOSX_ARCHS = -arch i386 -arch x86_64
> MACOSX_ARCHS_WXPYTHON?
MACOSX_ARCHS_WXPYTHON =
That is, there is nothing there. Maybe this is the problem.
> Just a check, because if MACOSX_ARCHS_WXPYTHON is wrong, wx nviz and vdigit would have failed also.
> ... maybe the xganim makefile somehow didn't get updated in your copy of trunk? is this line in the xganim makefile (followed by some subst mangling):
> ifneq ($(MACOSX_ARCHS),)
# substitute OSX arch flags for wxpython
CFLAGS := $(subst $(MACOSX_ARCHS),,$(CFLAGS)) $(MACOSX_ARCHS_WXPYTHON)
CXXFLAGS := $(subst $(MACOSX_ARCHS),,$(CXXFLAGS)) $(MACOSX_ARCHS_WXPYTHON)
LDFLAGS := $(subst $(MACOSX_ARCHS),,$(LDFLAGS)) $(MACOSX_ARCHS_WXPYTHON)
endif
Michael
