[GRASS-dev] xganim compilation on GRASS 7
Michael Barton Michael.Barton at asu.edu
Sun Jan 3 21:25:58 EST 2010
No error. Here's the configure result.
Michael
GRASS is now configured for:  i386-apple-darwin10.2.0
  Source directory:            /Users/cmbarton/grass_dev/grass70_dev
  Build directory:             /Users/cmbarton/grass_dev/grass70_dev
  Installation directory:      ${prefix}/GRASS-7.0.app/Contents/MacOS
  Startup script in directory: ${exec_prefix}/bin
  C compiler:                  gcc -g -O2   -arch i386 -arch x86_64
  C++ compiler:                c++   -arch i386 -arch x86_64
  Building shared libraries:   yes
  64bit support:
  OpenGL platform:             Aqua
  MacOSX application:         yes
  MacOSX architectures:        -arch i386 -arch x86_64
  MacOSX SDK:
  NVIZ:                       yes
  BLAS support:               no
  C++ support:                yes
  Cairo support:              yes
  DWG support:                no
  FFMPEG support:             no
  FFTW support:               yes
  FreeType support:           yes
  GDAL support:               yes
  GEOS support:               yes
  JPEG support:               yes
  LAPACK support:             no
  Large File support (LFS):   yes
  MySQL support:              no
  NLS support:                no
  ODBC support:               yes
  OGR support:                yes
  OpenGL support:             yes
  PNG support:                yes
  PostgreSQL support:         no
  Python support:             yes
  Readline support:           no
  SQLite support:             yes
  Tcl/Tk support:             yes
  wxWidgets support:          yes
  TIFF support:               yes
  X11 support:                no
  Regex support:              yes
  POSIX thread support:       no
cmb-MBP-2:grass70_dev cmbarton$
On Jan 3, 2010, at 7:21 PM, William Kyngesburye wrote:
> On Jan 3, 2010, at 7:48 PM, Michael Barton wrote:
>> MACOSX_ARCHS_WXPYTHON =
>> That is, there is nothing there. Maybe this is the problem.
> Ah, that's not right.  config.log - the arch check for wxpython is at the bottom (no errors would be completely quiet, I didn't put a log message in configure).  Any errors?
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "We are at war with them. Neither in hatred nor revenge and with no particular pleasure I shall kill every ___ I can until the war is over. That is my duty."
> "Don't you even hate 'em?"
> "What good would it do if I did? If all the many millions of people of the allied nations devoted an entire year exclusively to hating the ____ it wouldn't kill one ___ nor shorten the war one day."
> <Ha, ha> "And it might give 'em all stomach ulcers."
> - Tarzan, on war
