[GRASS-dev] xganim compilation on GRASS 7
William Kyngesburye woklist at kyngchaos.com
Sun Jan 3 21:44:19 EST 2010
no error in config.log?  Just checking since this is configure output, not log.
On Jan 3, 2010, at 8:25 PM, Michael Barton wrote:
> No error. Here's the configure result.
> Michael
> GRASS is now configured for:  i386-apple-darwin10.2.0
>  Source directory:            /Users/cmbarton/grass_dev/grass70_dev
>  Build directory:             /Users/cmbarton/grass_dev/grass70_dev
>  Installation directory:      ${prefix}/GRASS-7.0.app/Contents/MacOS
>  Startup script in directory: ${exec_prefix}/bin
>  C compiler:                  gcc -g -O2   -arch i386 -arch x86_64
>  C++ compiler:                c++   -arch i386 -arch x86_64
>  Building shared libraries:   yes
>  64bit support:
>  OpenGL platform:             Aqua
>  MacOSX application:         yes
>  MacOSX architectures:        -arch i386 -arch x86_64
>  MacOSX SDK:
>  NVIZ:                       yes
>  BLAS support:               no
>  C++ support:                yes
>  Cairo support:              yes
>  DWG support:                no
>  FFMPEG support:             no
>  FFTW support:               yes
>  FreeType support:           yes
>  GDAL support:               yes
>  GEOS support:               yes
>  JPEG support:               yes
>  LAPACK support:             no
>  Large File support (LFS):   yes
>  MySQL support:              no
>  NLS support:                no
>  ODBC support:               yes
>  OGR support:                yes
>  OpenGL support:             yes
>  PNG support:                yes
>  PostgreSQL support:         no
>  Python support:             yes
>  Readline support:           no
>  SQLite support:             yes
>  Tcl/Tk support:             yes
>  wxWidgets support:          yes
>  TIFF support:               yes
>  X11 support:                no
>  Regex support:              yes
>  POSIX thread support:       no
> cmb-MBP-2:grass70_dev cmbarton$
> On Jan 3, 2010, at 7:21 PM, William Kyngesburye wrote:
>> On Jan 3, 2010, at 7:48 PM, Michael Barton wrote:
>>> MACOSX_ARCHS_WXPYTHON =
>>> That is, there is nothing there. Maybe this is the problem.
>> Ah, that's not right.  config.log - the arch check for wxpython is at the bottom (no errors would be completely quiet, I didn't put a log message in configure).  Any errors?
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
The equator is so long, it could encircle the earth completely once.
