[GRASS-dev] grass/wx 6.4 problems on Debian sid.
Martin Landa
landa.martin at gmail.com
Mon Jan 4 12:29:14 EST 2010
2009/10/8 Glynn Clements <glynn at gclements.plus.com>:
> The other option is to abandon SWIG in favour of Python's ctypes
> module. This is more work, but it's also more flexible, and will
> produce a better result in the end.
honestly I don't know how to do it...
> It may even be possible to automate the wrapper generation. While this
> won't be perfect, neither is SWIG; any automatic approach has the
> problem that a C prototype doesn't contain enough information.
My attempt is to improve current situation and to make wxGUI
extensions working on MS Windows. I will appreciate any help from you.
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
