2009/10/8 Glynn Clements <glynn at gclements.plus.com>:
> The other option is to abandon SWIG in favour of Python's ctypes
> module. This is more work, but it's also more flexible, and will
> produce a better result in the end.
.. as long as you weren't intending to use swig + perl or java bindings ..
