[GRASS-dev] Some comments on the v.surf.icw add-on
Benjamin Ducke
benjamin.ducke at oxfordarch.co.uk
Mon Jan 4 13:31:21 EST 2010
I have just tested v.surf.icw in some detail.
In general, it is a very nice module that produces
far more realistic results than plain euclidean v.surf.idw
in the right circumstances.
I made some observations and have some questions/comments I'd
like to share:
Line 150:
This produces an error message from the shell if any of the
env vars does not exist (cosmetics, really):
if [ $GIS_FLAG_V -eq 1 ] || [ "$GRASS_VERBOSE" -gt 1 ] ; then
Line 234:
r.cost $VERBOSE -k in=tmp_icw_area_$$ out=cost_site.$NUM coordinate=$EASTING,$NORTHING
r.cost $VERBOSE -k in=tmp_icw_area_$$ output=cost_site.$NUM coordinate=$EASTING,$NORTHING
Otherwise, it won't play any longer with newer versions of r.cost
that have the "outdir=" option.
Line 239:
This changes the original input data without any warning or
documentation about it:
# so the divisor exists and the weighting is huge at the exact sample spots
# more efficient to reclass to 1?
r.mapcalc "cost_site.$NUM = if(cost_site.$NUM == 0, 0.1, cost_site.$NUM)"
Apparently, this is done to avoid a divison by zero in the standard
IDW formula (line 246):
EXPRESSION="1.0 / pow(cost_site.$NUM $DIVISOR, $FRICTION )"
If so, it needs to be documented. I actually used costs
normalized to [0,1] and ran into trouble here.
I realize now that wasn't a good idea, because a movement
costof "0" between two spatially distinct locations is physically
implausible. However, this behaviour still needs to be document,
perhaps advising users to use a minimum cost of "1"?
Line 246:
The variable $DIVISOR is never initialized (empty) but still
used in the expression:
In addition, I would like to know where the second
IDW formula comes from (-r flag). Any literature
references? When would this be the preferable formula?
Thanks,
Ben
Files attached to this email may be in ISO 26300 format (OASIS Open Document Format). If you have difficulty opening them, please visit http://iso26300.info for more information.
