[GRASS-dev] Re: [GRASS GIS] #660: v.delaunay producing incorrect results
GRASS GIS trac at osgeo.org
Mon Jan 4 21:41:26 EST 2010
  Reporter:  cmbarton  |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect    |      Status:  closed
  Priority:  critical  |   Milestone:  6.4.0
 Component:  Vector    |     Version:  6.4.0 RCs
Resolution:  fixed     |    Keywords:  delaunay
  Platform:  MacOSX    |         Cpu:  OSX/Intel
Comment (by hamish):
 Nice.
 How does it perform when the number of input points > 10,000 (& up to
 ~3M)? which was where the old v.delaunay1 fell over?
 re. the patch, three minor comments after a cursory look.
  1) MarkusM, you is the man, congrats
  2) TRUE=1, FALSE=0 is defined by gis.h, no need to repeat it.
  3) cmp_v() appears to test two FP values with ==. Should it use
  if( fabs(val1 - val2) < GRASS_EPSILON )
 instead? Is it looking for itself or another point at the same place as it
 is?
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/660#comment:39>
