[GRASS-dev] Re: [GRASS GIS] #809: v.db.addtable consistently fails
in winGrass
trac at osgeo.org
Fri Jan 8 05:21:04 EST 2010
#809: v.db.addtable consistently fails in winGrass
Reporter: JonBall | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: critical | Milestone: 6.4.0
Component: Vector | Version: svn-releasebranch64
Resolution: | Keywords: v.db.addtable, wingrass
Platform: MSWindows Vista | Cpu: x86-64
Comment (by mmetz):
Replying to [comment:13 hamish]:
> Replying to [comment:12 mmetz]:
> > I had a look at the vector lib routines for reading/writing
> > database connections (dblinks in the vector libs).
> > The database is written to dbln without parsing any variables in
> > it; that makes it possible to copy entire locations or provide
> > sample datasets with vectors and attribute tables. Any variables
> > in the database info are parsed by Vect_get_dblink() which calls
> > Vect_subst_var().
> However, there is no reason to assume that the user has not manually
connected the vector to a real pathname. And in those cases any code which
reads the dbln file will need to be able to deal with databases with
spaces in the path name.
Right, and it should also be broken on Linux if there are whitespaces in
the path name when manually connecting a table. A mystery that no one
discovered that yet...
> suggestion: This is really a failure of the dbln file format. In grass 7
change the dbln file format to use '|' as the field sep. Include code in
both the g7 and g6.5 the library functions to quietly read either during
the transition period. We have done something similar for the color table
format which used to be "value red green blue" but is now "value
red:green:blue".
OK. And use G_tokenize() I assume.
> You can't control what the map already has in it unless you rebuild the
map (which is perhaps not what you want). Another plausible possibility is
to add database= and driver= options to v.db.addtable.
Makes sense, and should not make the code too complicated. Something for
g7?
Markus M
Ticket URL: <https://trac.osgeo.org/grass/ticket/809#comment:15>
