[GRASS-dev] Re: [GRASS GIS] #858: Display command from the Output
window not working
trac at osgeo.org
Sat Jan 9 11:02:43 EST 2010
#858: Display command from the Output window not working
Reporter: clerici | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: closed
Priority: normal | Milestone: 6.4.0
Component: Tcl | Version: unspecified
Resolution: wontfix | Keywords:
Platform: Linux | Cpu: Unspecified
Comment (by hamish):
Replying to [comment:2 clerici]:
> Which is the new gis.m GUI?
typing "gis.m" at the GRASS> prompt will explain it better than me. :) but
I'll try.
> The one currently opened in GRASS6.5 (and 6.4) or a new one?
well the one that opens with grass 6.4 or 6.5 is the one you've
set to be the default GUI. There are three to choose from. Look in
~/.grassrc6. (GRASS 7 only has the one wxPython one)
gis.m has been around 2 years or so. It took over from d.m (still
available in 6.x btw), which took over from GRASS 5's tcltkgrass GUI. The
wxPython GUI first shipped as an optional extra with 6.3.0 but is only now
reaching real maturity.
see the user interface section of the screenshots page on the main
grass website for some pics.
> If, as I suppose, is the currently opened one,
(I've got no idea at what you are looking at)
> what's for the lower part of the window? Just for input of the
> commands others than d.* ?
yes. The OSGeo4W native MS Windows build doesn't launch a terminal
box by default. IIRC Lorenzo's Mac build gave you the choice not
to have one either. As most of the books, tutorials, and help examples
rely on command line entry there needs to be a way for folks without a
command line (or who are frightened by it) to enter commands.
> And what's for the Run(background) button?
The regular Run button waits for the program to finish before it gives you
back control. For example if you Run "d.mon x0" the button will be greyed
out until you close the monitor window. Where as run in background will
break it away from the GUI and it will be free to run on its own.
> As there are many others more convenient ways of command line
> input, shouldn't it better to entirely delete the lower part of
> the window and related buttons?
there are better and more convinient ways of doing lots of things in this
world /if you already know how/. Some people prefer working entirely in a
GUI, others spend most of their time in `screen` or emacs or Facebook.
shrug. One size does not fit all so it's just more choices to suit more
people.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/858#comment:3>
