[GRASS-dev] Re: [GRASS GIS] #809: v.db.addtable consistently fails
in winGrass
trac at osgeo.org
Fri Jan 8 13:11:11 EST 2010
#809: v.db.addtable consistently fails in winGrass
Reporter: JonBall | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: critical | Milestone: 6.4.0
Component: Vector | Version: svn-releasebranch64
Resolution: | Keywords: v.db.addtable, wingrass
Platform: MSWindows Vista | Cpu: x86-64
Comment (by mmetz):
Replying to [comment:16 hamish]:
> I've just attached to this ticket a patch against 6.5 which allows
spaces in pathnames for hardcoded database paths using G_tokenize().
> please review.
Tested, works fine. One minor bug though: in the new v.db.addtable line
129
eval `g.findfile elem="vector/$GIS_OPT_MAP" file=dbln`
does not work with a fully qualified name, the default settings in
$MAPSET/VAR are used. Maybe something like
eval `g.findfile elem=vector file=$GIS_OPT_MAP`
eval `g.findfile elem=vector/$name file=dbln mapset=$mapset`
> previously there was behavior in Vect_read_dblinks() which allowed the
dbln file to only contain the layer number and table name if you'd already
defined the others in previous layer links.
> I've tried to preserve that, but if the path has spaces I don't think it
is possible to distinguish between if the last entry is supposed to be the
driver or the end of the path name. Therefore we lose a tiny bit of
functionality here, but I don't think anyone knew about or was using that
trick anyway.
In grass64+, Vect_write_dblinks() always writes the full connection
definition, so I would not worry too much. I have not looked at previous
versions though to see if for layers > 1, only layer number and table name
were written if the rest was identical to layer 1.
For grass7, I would suggest to use fs="|" as default (anything but
whitespace) whenever dblinks are written or printed, e.g.
Vect_write_dblinks() and v.db.connect -p
Markus M
Ticket URL: <https://trac.osgeo.org/grass/ticket/809#comment:18>
