[GRASS-dev] Re: [GRASS GIS] #843: v.digit broken on new WinGrass
release
trac at osgeo.org
Fri Jan 8 14:36:32 EST 2010
#843: v.digit broken on new WinGrass release
Reporter: cnielsen | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: blocker | Milestone: 6.4.0
Component: Vector | Version: unspecified
Resolution: | Keywords: wingrass,v.digit
Platform: MSWindows XP | Cpu: x86-64
Comment (by hellik):
Replying to [comment:18 hamish]:
> this is a blocker as 2 of 2 vector digitizers are now broken in current
6.4 wingrass. Fortunately the solution for the tcl one seems well in hand
& forthcoming. Will backport revert then sync solution to the 6.4 branch
as soon as it is tested & confirmed in 6.5.
from dev-ml:
Hamish wrote:
> > * 843 v.digit broken on new WinGrass release
> > -> contains a suggestion
> Maris and Glynn are working to resolve this. Seems plausible that it
> will be backported and ready for final testing by next week.
FWIW, I've changed 6.5 as I consider appropriate, i.e. removed
$(FORMLIB) and sync'd generate.c to lib/form's version.
tested on a fresh build of grass65 on WinVista32:
=> v.digit is working
Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/843#comment:19>
